Unfortunately that was with the tail gate off. Thats why the fast guns were in the cab with me. Also my heavy duty rubber bed mat was in also. I already know I will probably be over 14k when loaded. It's just a matter of how much. Will it be 1400 lbs or 500 lbs. I will be weighing it a few times when I get it and I will post all the weights. Also remember my empty weight was with full fuel and def and all the tie downs etc.
Wife and I etc.
I use 6 volt batts because I have used them before. My first 2 coaches used 12 volt batts. After that I always
had 6 volt and they lasted longer. I think it has something to do with heaver plates in the 6 volt vs 12 volt batts. Either way I like the 6 volt ones. I probably could get away with using 4 but i like 6 better. It will be wired up so I can run the entire camper off the inverter. It does have an auto transfer switch. So if I'm plugged in to shore or gen set it just passes thru. I would not attempt to run the AC or the fireplace off the batteries for very long at all. Even with the truck ideling I think it would be a bad idea. I have dual 440 amp alternaters on the truck but still wouldn't let it go for long. Easier to just fire up the Honda 2k.
