Well I pulled the trigger on a pair of Honda Eu2000is parallel kit with covers. I chose to go this route after much thought between these generators and the eu3000is and the Champion 3400 watt generator. All could have worked for me but mainly it came down to weight of the bigger generators. The main drawback to me for the eu2000is is the small fuel tank, but this can be fixed easily with a extended run tank. I eventually ruled out the Champion due to the small tank and wasn't too keen on using the extended run kit which required the installation of a fuel pump. The eu3000is is a great option other than it's really heavy and I plan on hauling all this on the front cargo carrier.
