zb39 wrote:
That is a great looking RAM. Do you attach the tie downs to the rail on the side of the flat bed. Do you have anything else to prevent side to side movement, or is this not a problem. I also like your tool boxes.
The short range FastGuns are tied to the deck rub rails at the stake pockets. The front of the Arctic fox was blocked against the headache rack since this TC was designed for a short bed truck. The TC sits on 3/4" thick horse stall mats to clear the goose neck hardware in the center of the deck but no side bracing was required. I have a stripe marked on the center line of the TC and mats to line it up on the deck - If I had some type of physical guides, loading would be easier.
Once we get our Host, I will be looking at building out the sides for additional storage or filling the voids under the wings with tool boxes. I did not do this yet because the Arctic Fox dimensions were different and I did not want to pay twice for this storage.
