Bedlam wrote:
zb39 wrote:
I will be putting 4 6 volt batts in the gen compartment and 2 6 volts in the batt compartment. The 4k inverter will go in the main basement. It has a auto transfer switch built in so the 120 volt will run thru it. It is a pure sine wave and will run the whole coach. I will still carry one of the Hondas for hours of use with the AC or FP.
I've mentioned it before, but I wish Host would relocate the exterior shower to a non-electrical bay or dedicated cutout. Also, I found having a quick disconnect at the shower is much handier than a fixed hose.
I agree, in another compartment would be best. The hose on mine was hand tight so I already un screwed it and took it off. I will carry it if I need it. I will just screw it back on. I took that panel off to look at the incoming 120v line. There is room under there to make the compartment taller, but it would be close as to whether you could get a Honda in there or not,
prob be easier to extend the bottom down a few inches. Have I mentioned how quick the slides are. All 3 slides can be opened or closed in about 9 or 10 seconds. Doing 1 at a time. Way quicker than any MH I ever had.
