The same basic shell between the Everest and Mammoth, but the left kitchen/bath side is shorter so the rear couch slide can be longer. The location of the fridge did not make sense and you lose the pantry and fireplace on the middle wall of the Everest. We did like the cab over layout better and Host will put that in the Mammoth. If you look at the layout options of the Everest and Mammoth cab overs, any of those can be done in either unit. Although I don't see it advertised, you may be able to replace the dinette with a second couch in the Everest. If you are set on getting the external TV bay, it is only available in the Mammoth and Chinook models.
