Bedlam wrote:
The inner rear and spare are steel. These are 10-lug on a 225mm circle which is shared with the Fords of the same size, but I don't think you can find the Alcoa's in the correct 8-lug patterns. American Force and Vision should make alloy 19.5's that fit your DRW. I have friend with a F350 DRW running the Vision 19.5's.
Bedlam, What method do you use to rotate your tires? I have Alcoa with inner steels and got many different opinions on how even not rotating tires at all from other members and some dealers. So far have just rotated fronts side to side.
