Host sent out a kit to its owners to address two items:
1. Lack of main breaker off batteries
2. wire harness not sufficiently secured under passenger side slide
Here you can see my batteries connected to lines running into the generator compartment. There is no safety until it gets to the DC fuse box.
Adding a breaker in the battery box solves this problem. By mounting the breaker above the rivets on the back wall, the screw ends go behind the control panel in the generator compartment.
The passenger slide mechanical bypass and wires in question sit under a cabinet floor on the Mammoth.
This floor is attached by one screw near the cabinet door. If you don't have the outside TV or external speakers, you will not see all of these wires.
Those wires above are clear of the mechanism. The ones that need to be secured go to the master cutoff switch.
