The DPF is used not only on the small diesel engines put into pickup trucks but also the big rigs on the highways as well. The fleet operators view it as something to manage and not to whine about.
The same kind of whining took place in the 1970's when catalytic converters were added to gas engine exhaust systems. Same kinds of delete kits were being sold for them as are now sold for eliminating the emissions controls on diesels by their young owners.
A DPF does reduce fuel economy but far less than driving above the speed limit and the extra fuel burned with the latter does not seem to bother anybody so it is a specious argument to be making. I view the DPF and the need for DEF is part of the price for operating a diesel, and professional fleet operators do the same and they are dealing with hundreds or even thousands of trucks in their fleets.
The older diesel engines are less reliable to start with when taken as a whole and they were not engineered to burn ultra low sulfur diesel fuel or to burn B20 biodiesel fuel. There are always trade-offs and if you want the most economical power choice (in terms of total cost of ownership and operation) for an RV go with a gas engine.
One notable advantage with the Cummins diesel engines that are put in the Ram pickups is that they use the same filters as the big rigs and so you can easily upgrade to a 2-micron or even a 1-micron filter and reduce particles getting into the injectors by 90-99%. The 4-micron filters that are only 98.7% effective at best still let through more than 240,000 particles per gallon of diesel that is burned and with the high pressure common rail fuel systems these particles are hitting the insides of injectors at extremely high speeds.
