kohldad wrote:
Does the EVIC stay where it was last or do you have to scroll down to it each time you start the truck?
On mine it stays where you left it last. You can scroll to individual gauges or have then all listed at the same time. There is trans temp, oil pressure, engine oil temp, coolant temp and volts. I have the gas engine the diesel may differ. I should also add you can look at a digital Speedo, mpg's, tire pressures in all six tires, trip A odo with mpg's and trip B odo with mpg's. My truck is the base Tradesman model with Uconnect 5.0.
