work2much
Oct 17, 2017Explorer
path1 wrote:
If its being made "solar ready" (not the panels, but the actual wire) find out what size of wire they are putting in. You might want a larger wire size and easy to do when making, lot harder once you get it home.
Good advice. We had a AF1150 and we ended up running the solar wires down through a cabinet on drivers side, through the kitchen and down to battery box. If AF will upsize the wiring from roof to battery box I would go for that but you need to know where the wires are going to accept mounting a solar charge controller. We ended up with this install. A pretty basic renogy MPPT. To get to the battery compartment required lots of drilling of roof, walls etc...
