- blt2skiModerator
Cummins12V98 wrote:
"Origin of power stroke engine"
MEXICO
Friend one. Navigate supplied ones were here in states. At least NA supplies vs Asian! - Cummins12V98Explorer III"Origin of power stroke engine"
MEXICO - spoon059Explorer IIII still want to see that 100 mpg carb I've been hearing so much about...
- Turtle_n_PeepsExplorerOP, the Powerstoke first came out in 1994. No gasoline redesign here. It was a great design for the time, and state of the art with juice injection and a pure clean sheet diesel design from the get go. Even to this day they are a great engine. Down on power for today’s standards, but still a great engine.
As far as any other diesel engine being a gas redesign. That will depend on semantics.
I own 5 of the Olds 350 diesels right now, and I say yes, they are a redesign gasoline engine. Why do I say that? Because most of the gasoline parts bolt right on the diesel. Same bolt spacing, same amount of head bolts, same water pump, same oil pan, same oil pump, same exhaust manifolds, same valve covers, basically the same heads minus the spark plug holes.
The blocks are even the same with some metal added here and there to put a stronger larger forged steel crank in place. They also put in a bit more metal up front so they can bolt the IP to the block to run off of the cam.
As far as how they came about? I read a story about an engineer that was in on that deal. It went like this:
It was 1976 and the Beetles were out and Donna Summer and the Bee Gee’s were in. Gas was at a very high price and the Japanese were cleaning our clocks with 260Z’s and Celica’s. Oh sure, we had Vega’s and Pinto’s. :R
GM had a bunch of tuna boats that used gas like a sailor drinks beer. They knew Americans loved their BIG cars but could not deal with $1.25 per gallon fuel prices. Then it hit one enterprising engineering person. What about a diesel engine? Great mileage and next to no smog to deal with!!!! Brilliant idea!!!
One problem though. They needed and engine like right NOW, but they did not have one or the time to design it from scratch. The engineer thought that they could use an existing design and be in production in less than 6 months. The Olds was a great start because it was a great strong engine to start with. So they took the same block design and changed a few things with it like casting a bit more metal here or there and put an injection pump on it and there you have it, a 350 diesel!!! Pretty smart really!
The little diesel came through with the mileage (my 6000 lb Caddie gets 30 MPG on the highway!!) Remember, back then diesel was ½ the price of gasoline. So you could ride in luxury at 60 MPG gas prices!!!!!! What a great deal!!!
Then the problems started. With only 10 head bolts to hold the head on they were good to go with an 8.5 to 1 gasoline engine. But with a 21 to 1 diesel, there was nothing but problems holding the head gaskets in place. Then there was the cold start problems. With 40 weight oil in the crank case and at 30 below zero these engines did not start too well. The people back then did not know any better so when their car did not start they did what they always did………………use a can of “mothers helper.” Well the ether collapsed the ring package and that lost even more compression and then you had to use ether at 70 degrees! That is where the idea of “my diesel is addicted to ether” came from.
All in all, these engines are junk. The only reason I like them is for the mileage they get and the fuel they can burn. That, and I know how to band-aid them up so they will last and run forever.
That is how the 5.7 liter diesel came into existence! Now you know the rest of the story! :B - blt2skiModeratorThe tm 6.2/6.5 motor was a ground up diesel from Detroit. The 6.2 was spend and designed as high mpg 305 gas motor. Ie similar hp/ torque specs. The 6.5 350 hp spec, 454 torque wise. Good motors for what they were spend as, many like those with the 350 diesel, and to a degree the Ford idi6.9/7.3, and first generation or two of the b5.9, went .me Tarzan, I have diesel motor. But none of these were that chest thumping powerful.
Th only thing the same about the idi7.3 and PSD 7.3 is displaced,event. Similar to the new cm 4.3 v6 and pre kids version, displacement only.
Marty - ACZLExplorerIF OP is referring to the Ford Powerstroke, I believe that moniker came about in '93 or '94. That's when Ford added a turbo to the 7.3 and called it "Powerstroke". Someone correct me if I'm wrong.
- ktmrfsExplorer III
tvman44 wrote:
GM is the only one I know of that ever converted a gas engine to diesel and all I ever heard about them was bad.
GM and VW did what I'd call "hurry up designs" on diesels based on some of the gas engine displacements and dimensions, and probably some common parts. Not sure I'd call them "conversions" as much as a "design and manufacturing levereaged development" I suspect that the designers, may have been excellent gas engine designers, they probably had little or no experience with diesel engine design and the end result was noticeable design flaws leading to short life.
IIRC peugot also introduced a diesel in this time frame and it was also plagued with problems, probably for the same reasons as GM and VW.
Remember, at this time, mercedes was one of the few mfg with any long term design experience in auto (car not truck) diesels, having sold them since about WWII. GM's detroit diesel division had lots of truck diesel engine experience. I guess that it didn't spill over into the car design division. GM actually had two diesels, the 350 V-8 and a 4.2 L 90 degree block V-6 in some cars. - trail-explorerExplorer II
RCMAN46 wrote:
You need to get your facts straight.
Here is a good article explaining the problems Oldsmobile had with their 350 Diesel. It was not a converted gas to diesel.
Oldsmobile 350 Diesel
that page was useless. - BenKExplorerMaybe folks will believe this article...I learned a bit about this topic from
one of my fav magazines...
Truck Trend Mag: Ford's Power Stroke Diesel History - Power Stroke Spotters' Guide - N-TroubleExplorerConverting a gas to diesel would be more work than building a diesel from the ground up as they really have nothing in common. To many water cooler discussions here leading to bad rumors...
44,067 PostsLatest Activity: Jun 05, 2026
