rbpru's avatar
rbpru
Explorer II
Jan 22, 2017
Ouch a broken spring.
We about 100 miles from home I had a spring break.
I was towing about 60 mph on I-65 and a car passed pointing to my TT. Sure up enough, smoke was rolling. Smooth highways all day, no jarring bumps, just a pleasant drive home. Then boom.
I have a used 2010, 25 ft. Dutchmen with 28,000 towing miles on it in the last three years. When I stopped, the rear passenger side rim had a baseball sized dent, the tire was shredded and the spring was broken.
The front tire was fine and again I did not notice any bump or jar while driving. The top spring was broken about three inches from the frame mount. It was a clean break with no rust.
My question is, has anyone else had this happen?
    Sure, it happens often enough. I'll bet that the spring broke where the next ply ends. Yes, a poor design.
    The dent in the wheel is a mystery and you may have hit something, could you post a photo?
    If the spring plies are starting to show sag or a bit of gap at the ends, they are fatigued and all should be replaced.
