covered_wagon
Jan 25, 2019Explorer
brholt wrote:covered wagon wrote:
You can easily make your camper walk right or left a little bit as needed when loading, but you need to get out and look how it is centered when it close to that hitting spot. Just lift one side of campers jacks, one front one rear, it will lean a little and creep to the other side when you lower down on all fours. This trick originated from Bob Mehrer ,founder of Snow River Campers, who also designed the first slide out.
Creep to the side you raised right?
It will move slightly toward the jacks on the lower side. Doesn't take much and you can do it a couple times if needed.
44,056 PostsLatest Activity: Jan 12, 2020
