Sam_Spade
May 20, 2016Explorer
Gdetrailer wrote:haste maker wrote:
We have a Winegard antenna...amplifier is turned on
You are out of luck, it WILL take a much bigger and better antenna to overcome the blockies and freezes.
Not much jumping to unwarranted conclusions here......is there ??
Answer: yes there IS.
You don't have enough information to make that sweeping statement.
For instance: WHICH Winegard antenna do they have ? And do they know that they probably need to turn it to get good reception from EACH channel that they switch to......and each different channel might require rotating it a bit ???
With most of them you can't just stick it up in the air and forget about it.
44,071 PostsLatest Activity: Aug 23, 2026
