- budwichExplorermake sure that you are turning on the amplifier
- fla-gypsyExplorer
haste maker wrote:
The problem we are now having is we keep losing the signal from the TV station & we get a blank screen, reading "low HD signal"...thought maybe the trouble was the wrong antenna..we have the crank up antenna that came on the roof from the factory.
Does it have the additional UHF dipole? - haste_makerExplorer IIThe problem we are now having is we keep losing the signal from the TV station & we get a blank screen, reading "low HD signal"...thought maybe the trouble was the wrong antenna..we have the crank up antenna that came on the roof from the factory.
- krobbeExplorerIt is the receiver that distinguishes between DigitalTV(HD) and analog television signals. Not the antenna. An antenna merely picks up the frequencies.
74% of DTV stations are on UHF (Ch14-51), 24% is on high VHF (7-13) and less than 2% will is on Low VHF(2-6). So an antenna that picks up those frequencies that you generally watch most frequently will perform better for you. The
Winegard Sensar IV DTV/HDTV Antenna is a good one to pull in weaker signals as it is directional. - beemerphile1ExplorerI don't understand the question. First, there is no such thing as an HD antenna. There is also no such thing as a digital antenna.
The antenna that came on the RV is an "outdoor" antenna. So what is it you are wanting to accomplish? That info would help with giving answers. - RoyBExplorer IIII first tried the Hide-away Dual Dipole antenna, then the KING antenna, The WINEGARD Batwing antenna with UHF dipoles, the LOWES $90 yagi long beam antenna, and the Eight BOWTIE flat array antenna.
The dual dipole was a neat idea but it did not have much gain. It did pickup in all directions however.
When aircraft flew over head I would get phasing signals however - would blank out digital TV modes...
The KING is apparently more NARROW BEAMED meaning you really have to point the antenna right at the transmitting station where the BATWING has a larger BEAM WIDTH. Both antennas did the same great reception for me here in Northern Neck Virginia some 50 miles away from the DC area. The BATWING was able to pick up both groups of the WASHINGTON DC transmitters with a single pointing angle. I could not do this with the JACK. Had to move the antenna everytime to pick up all of the NATL BROADCAST CBS-NBC-ABC-FOX-PBS HDTV signals... My test antenna setup was on 15-foot PVC pole in clear view towards Washington DC.
The JACK antenna probably is a tad better gain wise but with all the simple tests I ran here at my location looking at WASHINGTON DC digital Natl Broadcast TV Transmitter Stations that are situated on both sides of DC I finally decided the BATWING was still the best for me.
I really had fun with this YAGI antenna from LOWES. It really pulled in the VHF and UHF digital HDTV signals. Made several trips to the OFF-ROAD camping with this. The big problem I had was rotating this around without hitting trees on both sides of my trailer. Lots of folks would stop by and look at this monster on the roof of my POPUP haha... This lasted for a good 6 months and finally I destroyed the antenna by taking it down so many times before we headed back for the house. I finally broke some of the folding metal sections getting it ready for transport.
This antenna panel is probably the best antenna I have ever owned. It picks up the most digital stations here at home and has great front to back rejection. Where we live Washinton DC is 50 miles North and Richmond is 50 miles to the South. This panel antenna just doesn't travel good with my POPUP setup. IT worked great but was difficult setting it up for each camping site. I was afraid I was going to damage it like I did on the Lowes YAGI so I stopped trying to use this out in the woods... It is on my house now as my primary OTA antenna...
I never played with any of the newr ROUND antennas they have now. I suspect these omni-directional antennas don't do very well unless you are right in the neigborhood of the transmitting antennas.
Just make sure your BATWING antenna looks simialr to this photo. Note the DIPOLES added to the front of it... The older BATWINGS didn't have this. You can purchase the WINGMAN ADD-ON from AMAZON... These make the BATWING a much better UHF Antenna to pickup the HDTV signals with.
Roy Ken - dockmasterdaveExplorerLook up the wingman.
It just clips on the standard wineguard and greatly improved our HD reception. @ $29 I think is what I paid. - Sam_SpadeExplorer
haste maker wrote:
Has anyone added an outdoor HD TV antenna to the antenna that is on the roof from the factory? If so what did you use?
There is nothing special about an "HD" antenna.
That is a "snake oil" marketing term.
If you want a better antenna, tell us what you have now.
Some so called "HD" antennas are **** and some are good......just like with anything else. - westendExplorerI would assume that the OP is looking for an antenna with better reception. That would eliminate a paper clip and other small "fad" antennas.
The two commercially available RV antennas (Jack and Winegard) can be outperformed by many different antennas. It is the availability and functionality of how they are deployed that keeps them as the market leaders. - DutchmenSportExplorerYou can stick a paper clip into the back of the coax connection on your television and it will pull in HD stations.
Unless you can move your antenna higher, the bat-wing antenna is about the best you're going to get. There are other types out there, but "generally" reports on these forums ... they simply do not perform as well as the old tyle bat wing.
44,068 PostsLatest Activity: Jun 21, 2026
