We've got a 2014 Timber Ridge 240RKS and like it a lot. Some of that is the floorplan, but also the general constructions seems pretty good with quality materials.
We've had the trailer since October 2013 and used it a lot: bought in British Columbia, brought it across Canada to Ontario and then down to Florida and back. We've lived in it for 3-4 months.
I won't begin to list all the really positive things we like about the trailer. It would take too long.
But there have been some issues, most to do with electrical accessories:
- The Lippert remote control (for the outside lights, slide, stab jacks, awning) needed to be replaced. Outdoors RV mailed us a new one.
- The Lippert electric stab jacks are easily bent and the motors water-logged. Not sure what we'll do about that. Don't think I want the same jacks as a replacement.
- The electric slide out motor broke a shear pin. I replaced with a regular bolt, and Outdoors RV sent me some Grade 8 spares.
- The Shur-Flo water pump has busted its bypass valve and needs to be fixed/replaced. It works but is noisy. Outdoors RV has authorized a repair/inspection at a local Ontario RV dealer.
Construction issues include:
- with the slide open, the bottom right 1-2' of vertical gap between the slide and the shell expands from 1.5" to 2.3" and as a result, the rubber seals are not as effective. We once had driving rain force water through there and into the trailer. Since then, I've started stuffing the space behind the seals with a pool noodle cut to fit.
- the floor of the slide is solid marine grade plywood with a bottom plastic piece laminated to it. Unfortunately part of the plywood edge is exposed to the rain when the slide is open, although it may be sealed. I've asked Outdoors RV what, if anything, I should do about it, but no response yet.
- where the fibreglass front cap meets the roof corners, it didn't look like enough sealant was applied. So I added some some-leveling Dicor.
If we had to do it again, we'd buy the exact same trailer, but without the Lippert remote control and Lippert electric jacks.
