Passin_Thru
Jan 26, 2014Explorer
We have a 31 ft Arctic Fox built by Northwood, the Nash Family. They build 1st class TTs and I'd recommend the Arctic Fox as it will stay warm and not freeze up at 7 degrees, tho the windows will frost over pretty bad! We went from VA-OK after Christmas and came back to Branson Jan 2 where we had 7 degrees and one other camper in the park. Lots of deer. Buy a heated hose for $100 as they will be worth their weight and get insulation to put in the nose compartment as the bed is above it and around the intake water supply. Buy a mattress from Sleepys, Queen size Natures Image plush and you'll enjoy your TT instead of waking with a backache.Keep your Sewage hoses stored in a garbage bag with the ends attached and in the witer use them to dump and put them up as they will freeze solid too.Wehn you dump, put 10 lb of ice in the toilet and about 3 gal of water and it will stay clean and you won't need additives for odor.
