CptnBG
Aug 25, 2014Explorer
nm1oqrz wrote:
Hello OBXcamper. Just a suggestion on the use of stainless hardware. Screws are usually not a problem as they don't have much stress on them. Jack bolts are another matter as a stainless bolt has a strength about equal to a grade 2 common steel bolt. So if your jack hardware are common bolts your good, but if they were grade 5 or up like mine (grade 5) when the stainless is a weaker bolt, won't rust but weaker. Just keep this in mind.
Happy camping nm1oqrzOBXcamper wrote:
Very nice and better than new!! I'm slowly replacing screws and jack hardware with stainless steel. Shame the manufacturers don't use them to start with. Minimal cost.
I should clarify. My jacks have permanent studs, I'm only replacing the nuts and washers. Thanks for the tip though, I learned something.
44,056 PostsLatest Activity: May 04, 2014
