4Powells wrote:
Thanks all so much for the replies! There are two connections inside so there has to be a splitter. Need to find the location of that sucker and I could remedy that. Lol. Add that to my list of things to do when we return after Spring Break.
The cable for the 2nd tv usually comes from the back of the amplifier faceplate. Look at the Sat rewire link above and you will see where it more than likely splits and how to overcome the problem. If nothing else, remove the cable "in" connection from that plate and hook it directly to your sat. and see if it works before you do the rewire.
