Calicajun's avatar
Calicajun
Outside Kitchen Frig
Our TT has an outside kitchen with a small 120vac frig. The frig is rated at .8amp at 120vac, so that should equal 96 watts of power required to run the frig. If my math is correct.
So why can't I get the frig to run using a 350 watt 12vdc to 120vac inverter? Tapped into a 12vdc line running power to the heating unit but for some reason it just not running the frig. Volt meter shows there is power going to the inverter.
Anyone have a thought or two on this that might help would be nice.
Craig
