plasticmaster's avatar
Mar 12, 2014
outside shower hose question
My TT has an outside shower on the rear of the TT. We set up an enclosed shower tent at the rear of the trailer, but the hose for the shower head just barely reaches inside the tent. How do I install a longer hose and where would I get it? Thanks.
  • Bumpyroad wrote:
    does your hose connection to the RV have a standard garden hose type of fitting, or a specialized male plug in jobby? you probably can take the hose to lowes/home depot and obtain the correct fittings and length of hose desired.
    bumpy
    Cut it, get a hose adapter and add a new improved pocket hose. Than you can shower in your neighbors lot. That's a easy fix. Any hardware store will have what you need.
  • does your hose connection to the RV have a standard garden hose type of fitting, or a specialized male plug in jobby? you probably can take the hose to lowes/home depot and obtain the correct fittings and length of hose desired.
    bumpy
