I have a 2012 Dutchmen Bunkhouse that has an outside stereo. The stereo is broken...that is the light is on as if it is turned on but nothing is displayd on the screen, and it does not work. It ha...
I would guess that your outdoor stereo is in a conventional frame. If you could post a picture or a link, it would be helpful. If it is conventional. as others have said, it can be replaced with an automotive 12 V stereo head unit. If you wish to have the light off, you could install a small toggle switch in the stereo's constant power circuit to interrupt power to the unit and the kight. You will lose memory settings when switching it like that.
