spitts55
Jul 15, 2013Explorer
OVERDRIVE OR NOT
I have a 2011 travel trailer 22ft and a 2003 expler 4.6 class three hitch with trailer tow do i use overdrive all the way to my destination or not .thanks
Nvr2loud wrote:
I have a 2011 Sierra with the 5.3 and use the tow/haul button when towing my 30 foot trail cruiser. I have found that the Sierra rarely goes into 6th gear (second overdrive gear) when towing anyway. When very hilly it hunts from 4th to 5th (first overdrive gear)and I manually lock out 5th and 6th gears when this occurs. Once the terrain changes again, I put it back into D and let the transmission act as designed.
Back when I was towing with my 2001 Sierra, I kept 4th gear (overdrive) locked out since my tow/haul button stopped working anyway and the truck really struggled in 4th gear.
With my Acadia I lock-out 5th and 6th gear when hilly, and I allow 5th gear when flat, but 6th gear towing really increases my fuel consumption in that vehicle.
I always tow in tow mode
Gdetrailer wrote:LOL, I don't even know where to begin, I'll take your advice and knowledge on this subject...... never! 2000 f350 has no otw trans cooler, just an external, there are more, that is just one example. We need facts not speculation.peirek wrote:path1 wrote:
I want the fluids (transmission and coolant) to circulate faster than in overdrive mode.
This! It will make a difference in your Tranny fluid temps.
:R
Total B. S.tuff.
The fluids pumped around via transmission are NOT going to "circulate faster" whether in OD or not in OD.
What you MIGHT see though since the engine will be TURNING HIGHER RPMs is the engine COOLANT will get circulated faster to a certain extent.
The engine fan will also be running faster but at speed will not have much over all effect.
Folks tend to put WAY TO MUCH time and energy in worrying about engine coolant and transmission oil temps.
Folks, please understand the STANDARD configuration of modern day vehicles from the time automatic transmissions were invented the transmission fluid is plumbed into the radiator via a short loop internally in the radiator.
This loop is placed at the BOTTOM of the radiator tank where the engine coolant is the LOWEST temperature possible. This loop will keep the transmission fluid near engine coolant temps (that IS the way it is designed).
Additionally with vehicles which are factory setup for towing they will have a SECONDARY transmission cooler plumbed in AFTER the radiator loop.
99.9999% of the time this is plenty sufficient to keep the transmission temps well within the factory specs.
With that said, the OP should FOLLOW the FACTORY RECOMMENDATIONS OUTLINED IN THE MANUAL as to whether or not to lock out overdrive.
I myself HAVE NEVER locked out overdrive UNLESS the transmission continually "HUNTS" gears (down shift then up shift in a quick repeating pattern).
I towed with a 97 and 2003 truck with 4 speed automatic overdrives and I can only think of once or twice I locked out over drive and that was only for that particular grade.
Newer vehicles with Tow/haul mode is completely different, the T/H mode DOES NOT LOCK OUT OD.
I would say if the manual does not tell you to lockout OD while towing then try driving with OD and if transmission downshifts and upshifts too much (up/down quick pattern) then lock it out. The continual shifting is actually where damage can come from, not the fluid temps.
limbery wrote:
My TV has a tow mode switch which disables overdrive for pulling trailers...
nevadanick wrote:
I had a pickup with a 4.6 and my experiance is it will never shift into overdrive pulling something anyway, so i wouldnt worry about it.
Terryallan wrote:
My manual says the trany will stay cooler wit OD locked out. For the same reason. The fluids circulate more, because there is higher RPM. I also get better MPG, and better performance with OD locked out. My engine is MUCH happier turning a little more RPM.
To the OP. I wouldn't worry too much. Your trany ain't gonna hold OD anyway.
