OregonMan
Sep 12, 2022Explorer
Overhead oven fan not working in trailer
Hi guys so the overhead oven fan in my travel trailer hasn't been working, when I turn on the switch for either the light or the fan, neither works. This started happening after I ripped the C02/propane detector out of the wall out of aggravation when boondocking because it would always beep incessantly once the trailer battery started running low. Yeah I know, dumb move. I've since gotten a battery operated C02 detector. Is it possible that when I ripped that wired C02/LP detector out of the wall, it pulled a connection loose from the circuit board that goes to the oven fan? The circuit/power board is located under the fridge right next to where the C02/LP alarm was previously located. I'm no electrician but I could probably see if a connection is loose back there. All other lights and electronics work fine in the trailer. Thanks for any tips.
