Tiger4x4RV wrote:
You could just get a Tiger. 4x4 pickup chassis, back of cab cut off, coach mounted onto chassis. Cutting off the cab back makes it a class C with pass-through between cab and coach. Built to order at the factory. New ones are pricey and used ones are scarce. I always say there is no perfect RV, but the 2006 Tiger CX which I bought new is by far the closest thing to a perfect RV for me.
For overlanding, once you get out of N. America, you have an oddball vehicle if you need work done on it.
Also, it's up around $150k starting price for a stripped down version and you only get a 9ft box. Basically it's a truck camper with slightly wider floor space.
I agree there is no perfect RV. For cruising around N. America, overlander vehicles don't make a lot of sense.
