Turtle_n_Peeps
Aug 30, 2016Explorer
ktmrfs wrote:Turtle n Peeps wrote:Tyler0215 wrote:
Politics aside please. The science is there.
Bio-diesel or ethanol blends have been proven to not harm engines or components.
I have used ethanol blends in all my vehicles for many years with no problems at all.
Really? Pretty interesting statement considering every single diesel maker disagrees with you. You know something that they don't?
First there are compatibility problems.
Then there is the problem with the SCR and DPF systems.
Then there is post injection problems with Biodiesel.
Need I go on? And I didn't even talk about Alkie in gasoline! :R
Where do some of you come up with this stuff? The disinformation and misinformation on this forum is astounding! :R
if every single mfg disagrees, why are at least 3mfg certifying the current diesels vehicles for use with B15 and in most cases B20 and have certified use of B5 for more than 10 years.
yes, initially there were compatibility problems with high blends with seals, hoses etc. but those were adressed easily long ago and never was an issue with B2 of B5.
and none of the links you posted are from a vehicle mfg. paper yes, validity with VOE well subject to careful examination for sure before concluding anything. and at least one is 5 years old.
Every single manufacture says bio is hard on engine parts.
#1. Name one engine manufacture that recommends running 100% bio; or even 50% for that matter? Oh that's right, there is none. Do you know why? Because it's hard on engine parts.
#2. Look at the oil change schedule for straight #2 and then for a #2 bio blend. Oh, look at that; if it's a #2 bio blend you have to follow a severe oil change schedule. I wonder why that is? :R Do you know why?
#3. Bio is hydroscopic and holds water in suspension; how compatible do you think that is with a CP4-x pump? :R
#4. Not all people on this forum own new trucks. Try running bio or even a strong bio blend and see what happens to your hoses or rubber parts. Let me know how that works out for you. :B
#5. Not all people have old trucks on this forum. Try running 100% bio in them and tell me how it works out for your SCR and DPF for you. :B
#6. The manufacture of my truck says no more than 5% bio; PERIOD! Some states mandate over 5%. Some 10%. Do you think it's a good idea to go 100% over manufacture specs? What about 150 or 200%? Is that ok also? :R
44,071 PostsLatest Activity: Aug 16, 2026
