SBradley
Dec 08, 2016Explorer
A new study points to the negative results of using Bio Fuels.
University of Michigan’s Energy Institute research professor John DeCicco, Ph.D., believes that rising carbon dioxide emissions cause global warming and, therefore, humans must find a way to reduce its levels in the atmosphere. But ethanol is the wrong solution.
According to his just-released study, political support for biofuels, particularly ethanol, exacerbates the problem instead of curing it.
DeCicco and his co-authors assert: “Contrary to popular belief, the heat-trapping carbon dioxide gas emitted when biofuels are burned is not fully balanced by the CO2 uptake that occurs as the plants grow.” The presumption that biofuels emit significantly fewer greenhouse gases (GHG) than gasoline does is, according to DeCicco: “misguided.”
His research has upended the conventional wisdom and angered the alternative fuel lobbyists. The headline-grabbing claim is that biofuels prove worse for the environment than gasoline.
DeCicco has been focused on this topic for nearly a decade. In 2007, when the Energy Independence and Security Act (also known as the expanded ethanol mandate) was in the works, he told me: “I realized that something seemed horribly amiss with a law that established a sweeping mandate which rested on assumptions, not scientific fact, that were unverified and might be quite wrong, even though they were commonly accepted and politically correct (and politically convenient).” He saw that while biofuels sounded good, no one had checked the math.
Previously, based on life cycle analysis, it has been assumed that crop-based biofuels, were not just carbon neutral, but actually offered modest net GHG reductions. This, DeCicco says, is the “premise of most climate related fuel policies promulgated to date, including measures such as the LCFS [California’s Low Carbon Fuel Standard] and RFS [the federal Renewable Fuel Standard passed in 2005 and expanded in 2007].”
The DeCicco study, Carbon balance effects of U.S. biofuel production and use, uses Annual Basis Carbon (ABC) accounting—which does not treat biofuels as inherently carbon neutral. Instead, it treats biofuels as “part of a dynamic stock-and-flow system.” Its methodology “tallies CO2 emissions based on the chemistry in the specific locations where they occur.” In May, on my radio program, DeCicco explained: “Life Cycle Analysis is wrong because it fails to actually look at what is going on at the farms.”
The concept behind DeCicco’s premise is that the idea of ethanol being carbon neutral assumes that the ground where the corn is grown was barren dirt (without any plants removing carbon dioxide from the atmosphere) before the farmer decided to plant corn for ethanol. If that were the case, then, yes, planting corn on that land, converting that corn to ethanol that is then burned as a vehicle fuel, might come close to being carbon neutral. But the reality is that land already had corn, or some other crop, growing on it—so that land’s use was already absorbing CO2. You can’t count it twice.
DeCicco explains “Growing the corn that becomes ethanol absorbs no more carbon from the air than the corn that goes into cattle feed or corn flakes. Burning the ethanol releases essentially the same amount of CO2 as burning gasoline. No less CO2 went into the air from the tailpipe; no more CO2 was removed from the air at the cornfield. So where’s the climate benefit?”
Much of that farmland was growing corn to feed cattle and chickens—also known as feedstock. The RFS requires an ever-increasing amount of ethanol be blended into the nation’s fuel supply. Since the RFS became law in 2005, the amount of land dedicated to growing corn for ethanol has increased from 12.4 percent of the overall corn crop to 38.6 percent. While the annual supply of corn has increased by 17 percent, the amount going into feedstock has decreased from 57.5 percent to 37.98%.
The rub comes from the fact that we are not eating less. Globally, more food is required, not less. The livestock still needs to be fed. So while the percentage of corn going into feedstock in the U.S. has decreased because of the RFS, that corn is now grown somewhere else. One such place is Brazil where previous pasture land, because it is already flat, has been converted to growing corps. Ranchers have been pushed out to what was forest and deforestation is taking place.
Adding to the biofuels-are-worse-than-gasoline accounting are the effects from producing ethanol. You have to cook it and ferment it—which requires energy. In the process, CO2 bubbles off. By expanding the quantity of corn grown, prairie land is busted up and stored CO2 is released.
DeCicco says: “it is this domino effect that makes ethanol worse.”
How much worse?
The study looks at the period with the highest increase in ethanol production due to the RFS: 2005-2013. The conclusion is that the increased carbon dioxide uptake by the crops was only enough to offset 37 percent of the CO2 emissions due to biofuel combustion.
DeCicco’s research finds, that while further work is needed to examine the research and policy implications going forward, “it makes more sense to soak up CO2 through reforestation and redouble efforts to protect forests rather than producing biofuels, which puts carbon rich lands at risk.”
How much worse?
44,071 PostsLatest Activity: Aug 16, 2026
