- JoshuaHExplorerThanks, I really appreciate you doing this.
- All_I_could_affExplorerHere is everything I have from my 1999 Bantam B17, hope it helps
- bikendanExplorer
All I could afford wrote:
There should also be a sticker with cargo carrying capacity specific to your actual model as equips from the factory on one of the kitchen cabinet doors.
Yep, white factory weight sticker. It may include tank capacities. It'll be inside a cabinet wall or door. - JoshuaHExplorerThank you very much for this info, very helpful.
- All_I_could_affExplorerThere should also be a sticker with cargo carrying capacity specific to your actual model as equips from the factory on one of the kitchen cabinet doors.
- Ralph_CramdenExplorer II
JoshuaH wrote:
I'd really like to know how much payload it can safely carry as well. Any and all specs would be wonderful.
The GVWR on an 03 17H was 3755, 3500 lb axle less advertised hitch weight of 255. Cargo carrying capacity was @ 900 lbs. The tanks were black and gray 30 gallons, fresh water 24. Fresh was advertised as 30 but 6 of that is in the water heater which you can not get, unless you drain it out the heater drain plug. The 17H was renamed the C17 for 04 and layout was changed slightly. - Rover_BillExplorer IIOwner manuals for TT are generic and cover several model lines. To find the exact weight and payload specs for your TT, look for the USDOT GVWR sticker located on the street side near the front of the TT.
- JoshuaHExplorerI'd really like to know how much payload it can safely carry as well. Any and all specs would be wonderful.
- JoshuaHExplorer
I may have the dealership sales brochure for you trailer. If so I can make a copy if it has the info u need
I'd love that, or if you are willing to part with it I'd happily pay for it. I seem to find 2 different floor plans for that year, mine is the one with the door more towards the front. - All_I_could_affExplorerI may have the dealership sales brochure for you trailer. If so I can make a copy if it has the info u need
