Terryallan
Jun 27, 2014Explorer II
ScottG wrote:
No offense but those coopers aren't LT tires either, especially with a max pressure of 50 psi and 2600#. There's nothing that suggests they have stiffer sidewall since they don't have a letter load range rating. Keep in mind that a rated load in lbs has little to do with sidewall stiffness. That's where the LR E rating comes in and that's where a true LT tire shines.
I would hold out for a true LT tire if you can find one - or even replace the wheels to facilitate them.
Actually having run these before. I can tell you. they are a lot more stiff than a P tire, and way more tire than I need. While my TT has no sway. The P tires allowed me to "Feel" it more. The Discoverer Plus don't.
