- bhhExplorerHere are some tips and techniques click here (I should add that I refinished some furniture pieces for this guy when he gave up part way through the stripping.)
I would add
* Prep : clean and dull
* Primer : I like BIN _Shellac_ based primer (they now carry a synthetic shellac version)
* Paint : Avoid inexpensive latex paint. These are prone to blocking. If you can get oil-based paint in your location (some low-VOC states make it hard to rind) I'd opt for that. There are other options but most of them require spray equipment and good ventilation. - westendExplorer
wickedstang03 wrote:
What about a paint primer combo?
No, that's a gimmick for lazy wannabes. - wickedstang03ExplorerWhat about a paint primer combo?
- getontheroadExplorerI would use one of the general finishes products, it is a gel stain. I don't know if it comes in white. I just redone a few cabinets in my laundry room there was no sanding. I used a good deglosser then used the general finishes product. Very nice turnout and was so easy I also applied the product to my old china hutch in java and it turned out very beautiful. I did all of this in one weekend.
- Sondy132001Explorer
I wish they would fix the issue with pictures not showing up...
Use photobucket.com, pics show up from there ! - RVcircusExplorer II
Dutchie1979 wrote:
I have used this product on my home kitchen cabinets without sanding, and it works great.
http://www.rustoleum.com/product-catalog/consumer-brands/zinsser/primer-sealers/bulls-eye-1-2-3-water-base-primer
They actually specify that sanding is not required with this product. The trailer would see far less use than a home kitchen so I think it would hold up just fine.
We also userd Bullseye primer and it's been holding up well so far. We also used this to prime over the wallpaper. - wickedstang03ExplorerI wish they would fix the issue with pictures not showing up...
- Sondy132001ExplorerWe lightly sanded our cabinets, then used primer and now we are using Nuvo Cabinet paint, I have a 1982 Fleetwood wilderness lite 18ft Travel Trailer and we are completely redoing the inside.
S
Before
After
- samhain7ExplorerIt will look as good as the work you put into it...
For this application, I would sand (paper or chemical)PRIMER and paint with an oil based paint. Some will try to say that latex or water based is as durable. But you will get many more miles out of oil....That is if you want to get many years out of it.
If you may be selling the trailer in a few years, I would take some of the other recommendations listed here. - wrenchbenderExplorerSherwin-Williams sells a great cabinet refinishing paint,but the secret is a good prep
