adamis's avatar
adamis
Nomad II
Sep 08, 2018
Painting the Interior
The wife and I have been discussing doing a bit of a makeover for our camper. Our 2001 Bigfoot has paper veneer face wood cabinets that we think we want to paint to a gloss white. I was wondering if anyone has taken on this task with a similar type of surface. Should we do a light sanding on the surface first? Since it's a veneer, I wasn't certain if sanding would be helpful or not.
  • My experience is that cabinets are often wood veneer which is just a thin layer of wood. Prep and paint accordingly. In my rig I found that some rounded corners were actually a plastic material that looked like wood - that might require a different approach.
  • Naio's avatar
    Naio
    Explorer II
    Is the veneer actual wood, or is it that stick-on wood-look stuff?
    You will definitely need to give it a light sanding. Or you could try a liquid deglosser, although I have never found one that was very effective. Much easier, though, if you find a good one.
    You will also need an extra sticky primer, like Kilz-2 or Gripper.
    My most important tip: Do sample patches. Lightly sand, degloss in a eparate area if you are trying that. Then do a patch each of a few different primers.
    Leave them overnight, then come back in the morning and try to scratch them off. Try your fingernail first. If you can't scratch the primer off with your nail, try scratching gently with something metal. Don't gouge the wood :-). But you want to choose the primer that will really stay on there. If you use something that scratches off easily you will be very disappointed in a year!
  • Surface preparation has always been my mantra....anything to really clean and lightly ruff up the surface. TSP back in the old days.
