mcaruso's avatar
mcaruso
Palomino 1240 /F250 8' bed
Going to pick up a palomino 1240 to put in my brand new F250 long box. I'm new at this and have a few questions. Do I need to remove the tailgate? Currently it's in a short bed truck with the tailgate on obviously it down. The second is it a good idea to put down a bed mat? Like the ones they sell at Tractor Supply? Any help would be greatly appreciated heading out tomorrow morning.
Thank you
  • Stall mats are not needed unless you need clearance. In which case, foam under a bed mat will accomplish the same or more and weigh less. Easy to figure if you have cab to overhead clearance before you go.
    Yes get a bed mat.
    Yes leave the tailgate home, you can decide later if you can or want to leave it on.
  • I think a rubber mat is a good idea. Having gone with a 3/4" stall mat and struggled with it too, I think a thinner mat like the Dee Zee is a good start. And if you need more height, go for the structural rated foam sheets under the mat.
  • I tried the horse mat nice thick material. Weighs about 100 lbs. After wrestling that around a few times I bought a dee zee mat that Weighs about 30 lbs.
  • I'd put a piece of structural closed cell foam on the floor. It comes in 4x8' sheets. I have 4" thick but that is my choice as I needed some height as I have lights on my cab roof.
    Inexpensive and light weight. In a TC weight is important.
  • Definitely get the rubber mat it keeps things from sliding around. As far as your Palomino, good luck with it I have never seen one but I would think you would want to leave your tailgate home as it is another 70 pounds. Good luck fellow Truck camper and welcome!
  • Leave yor tailgate at home.
    On the pictures of the 1240 I have seen, it has little side skirts wrapping around the truck's taillights.
    If your camper doesn't have these and you are able to close the tailgate (which I personally doubt), you can still put it back on and see how you like it.
    A rubber / stable mat under the camper is not a bad idea. I am sure more people will chime in.
