pratmaster's avatar
pratmaster
Palomino bronco question
I am trying to learn all I can about truck campers, I like to do a lot of research on things before I ever bother to start looking in person.
I have talked myself out of buying a camper right now as I will not have a need for one for at least 6 months, however I am still looking at them online since I have nothing better to do.
I have located a 1994 Palomino Bronco 1000 for 700 bucks, but it has had a leak in the front. The pictures show molded turned wood which I am assuming all needs to be torn out. This leak and rotten wood is in the bed area over the cab.
I have read that the broncos leak in the corners in the front a lot, and have other areas that are known to leak. As well as they are just a pain to rebuild or repair the rotten wood do to the way they are built from the factory. I read this info on this site and others like it by the way.
Anyway, I have decided not to even bother looking at this camper, but I got thinking about some of the newer ones I have also found online, 5-10 years old, that are $4-6,000 could be on there way to becoming rotten. then I find 2 dealers (IN & IA) that sell new Palominos for $8-9,000 +/-.
I do not want to spend that kind of money on a camper, and I need a travel trailer type more over a truck camper. But the trailer is a whole different animal and has its own set of issues for me. But this time I am looking at truck campers for me on short need basis and for enjoyment if I have time and money at the same time to actually have enjoyment...
Anyway, my question is about buying a new bronco a better idea over buying a used one for just a little less, or am I just over reading about the complications of replacing rotten wood in a camper.
I have done a lot of remodeling work in my down time for a few different people/contractors and I am quite handy repairing anything outside of concrete, I hate concrete.
Then I get thinking about the reason I bought a new truck,My old truck was rusty, old and worn out and every time I turned around I had something going wrong or costing me money... I can see an old rotten camper being the same way, however I could then at least gut it and change the floor plan, layout to my liking....
  • thanks for the input..
    Yeah, I pretty much decided I am going to just buy a new one when money allows, If this new gig works out, I can just pay cash for one the coming winter.
    I am not going to be home enough over the next 3 months, maybe 8+ months to deal with working on one anyway. I know what is going to happen, I will get it torn down, and find out that the material and labor involved is more then the dang thing is worth and scrap it.
    I already did this with a trailer camper a few weeks ago, I had nothing in it though.
    I think if I buy a used one, its going to be something cool like the Avaion, Barths or any of the other really cool aluminum truck campers...
  • pratmaster wrote:
    .....snip........
    ...snip.......
    My answer was and is to buy new. My time is better spent traveling and enjoying the RV lifestyle rather than doing repairs. Plus, in your case, the 2014 Broncos are a whole lot improved over the older models.
  • Lack of maintenance is the primary reason campers leak. Campers are basically houses that you're constantly trying to shake apart. If left outside they need to be recaulked every year or two, with proper RV-grade sealant like Dicor.
    Usually the fascination with camping will wear off and the camper will end up parked in the back yard and neglected. After a couple years they start leaking, and it's all downhill from there.
    Every repair project I've heard or read about has ended up being much larger in scope than what was seen on the surface. I personally would not buy a camper with known damage, EVER. You need to be persistent, diligent and patient to get the repair done. I don't enjoy that kind of thing, myself. There are other things that I'd much rather spend time repairing.
