camp-n-family
Feb 24, 2014Explorer
Another vote for the 4Runner, although I have no experience with the Pathfinder to compare. I've had both an '03 V6 and an '04 V8 4Runner. Both were fantastic vehicles that I wished I had kept but my needs grew.
If you want to stick with a V6 then the Toyota 4.0l is a strong engine. More horsepower and only slightly less torque than the 4.7 V8. For a $15k budget you would be in the 4th generation models ('03-'09) My only suggestion is to make sure you go '05 or newer as it comes with the better for towing 5 speed trans vs the 4speed in the older ones. I towed a 3800lbs hybrid with the V6 and it handled the weight fine but the tranny struggled to hold gears in headwinds. The 5 speed (same as in the V8) was much better and towed my 5500lbs TT like it wasn't even there.
Personally I would opt for the 4.7l V8 4Runner. Might be a little overkill but the engine is bulletproof and was only 1mpg worse than the V6 non towing but had the same or better mileage while towing.
44,070 PostsLatest Activity: Jul 22, 2026
