APT
Feb 24, 2014Explorer
jeffro61 wrote:
APT - the Rams and Fords you mentioned - are those trucks? Looking specifically for SUV/Vans - and have never had any luck with American vehicles or known anyone who did.
Yes, American based pickups, heavy duty ones at that. They will likely get the best towing fuel economy and allow you to tow comfortably with cruise control at 65mph up nearly any grade. It's too bad about your luck. The domestics sell about 2million pickups each year compared to the Japanese at about 150k per year. If they were so unreliable, the market would not be what it is.
Any V6 IMHO outside of Ford's Ecoboost will provide similar towing experience. You'll tow at 2500rpm on flat land, 12mpg, and downshift to 4000-5000rpm for hills. The only problem with that is some people mentally cannot handle it. If that's you, then 4-Runner, Pathfinder, minivan, etc won't do it. Nissin Titan or 2007+ Tundra 5.7L would hold closer to 3000rpm up those grade because they have far more torque at 2000-3000rpm.
$15k can get you into a 2010 GM 3/4 ton 6.0L/6-spd trans under 50k miles. The drivetrain is nearly bulletproof. You'll get the same towing fuel economy as the V6s with a lot more comfort. You have literally a ton of available cargo to put the the climate controlled back.
44,070 PostsLatest Activity: Jul 22, 2026
