wireman
Sep 20, 2017Explorer
Grit dog wrote:
Wall paper, yes. Sticky flooring, not as good of an idea. Pressure sensitive adhesive on flooring don't hold so well in a vertical,application. Hard to get even pressure to make it stick and then it's constantly bouncing and pulling on the wall behind it.
Maybe if you put some staples or tacks in it.
X2 getting this stuff to stay put on a moving house, bouncing down the road, on a vertical wall that is probably past 90 degrees with varying temps, seems almost impossible to guarantee it will stay.
The wall paper idea may be your best bet.
44,071 PostsLatest Activity: Aug 30, 2026
