Everyone wants to have a generator to run their whole trailer experience...
You would actually need at least a 4000WATT generator and probably would be better to get one in the 5000-6OO0 WATT range to cover all needs.
You would want to pick up one of these RV STYLE generator packages..
Then you would need to find a place to install it. Placing it on the trailer tongue or inside one of your precious storage compartments are about your only choices. Adding lots of weight to the trailer tongue has other problems to overcome... Also anything you mount outside is more prone to thief...
I would think behind the rear wheel of the trailer inside a storage door would be best to install something heavy.
Doing this would also be a hugh problem of cutting the floor out of the storage area and modifying things for good drainage and exhaust system along with wiring and fuel requirements...
After thinking about all of this to overcome it might be better to just beef up your trailer with smart mode charging, LED lights, other power savings techniques, and add more batteries to run inverters for 120VAC items and direct connected to 12VDC items. Plan the system to be able to run every 120VAC item and 12VDC item you want to run in one day/night run off the batteries. Then recharge your battery bank once a day starting at 8AM each morning when allowed to run a generator from the truck bed and be able to re-charge your battery bank back up to is 90% charge state so you can do all of this all over again for the next day/night run off the battery. You can also add solar panels to recharge your batteries during high sun days...
This is what we did haha... Of course it does not allow you to use your air conditioner or high power microwave but everything else works just fine...
All of this submitted for food for thought only..
All photos from google search...
Roy Ken
