rowekmr's avatar
rowekmr
Permenant Genset Instal
Has anyone installed a permanent genset on their travel trailer? I was thinking of this and thought the main issues would be fabricating a mount for the generator itself then the tank and associated wiring. I have been using a Champion generator for years (loud) but after renting a few MH's love the pushbutton electric start option and fully integrated power supply.
  • About 7yrs ago I helped a friend install a 3k Honda in a TT.It was placed on a tray and the tray had very heavy duty tracks to enable it to slide in or out.This eliminated the need for cooling fan and by having the unit away from the TT a tad quieter.It was out of site when not in use.It ran on propane.
  • We had an Onan Microquiet LPG fueled 3,600 watt installed. One consideration is our TH had a generator compartment from the factory. Many TT may not have a compartment that can be converted. It should be insulated and completely sealed from the interior of the trailer.
  • One of my biggest considerations for not installing a generator on board a TT, especially a lightweight one, is NVH - especially the vibration. No matter how soft mounted it is, there will be vibration transmitted thought the frame of he trailer and I don't think I'd like that. Better to have it not mounted on the RV as the NVH would be cut down dramatically. I know that is not what the OP asked about, but I thought that it could be worth mentioning the vibration issue.
    I am leaning towards the greener solution as Roy suggested. In the hotter months when AC is a must, I'd just as soon camp in an electrified campsite.
  • RoyB's avatar
    RoyB
    Explorer III
    Everyone wants to have a generator to run their whole trailer experience...
    You would actually need at least a 4000WATT generator and probably would be better to get one in the 5000-6OO0 WATT range to cover all needs.
    You would want to pick up one of these RV STYLE generator packages..
    Then you would need to find a place to install it. Placing it on the trailer tongue or inside one of your precious storage compartments are about your only choices. Adding lots of weight to the trailer tongue has other problems to overcome... Also anything you mount outside is more prone to thief...
    I would think behind the rear wheel of the trailer inside a storage door would be best to install something heavy.
    Doing this would also be a hugh problem of cutting the floor out of the storage area and modifying things for good drainage and exhaust system along with wiring and fuel requirements...
    After thinking about all of this to overcome it might be better to just beef up your trailer with smart mode charging, LED lights, other power savings techniques, and add more batteries to run inverters for 120VAC items and direct connected to 12VDC items. Plan the system to be able to run every 120VAC item and 12VDC item you want to run in one day/night run off the batteries. Then recharge your battery bank once a day starting at 8AM each morning when allowed to run a generator from the truck bed and be able to re-charge your battery bank back up to is 90% charge state so you can do all of this all over again for the next day/night run off the battery. You can also add solar panels to recharge your batteries during high sun days...
    This is what we did haha... Of course it does not allow you to use your air conditioner or high power microwave but everything else works just fine...
    All of this submitted for food for thought only..
    All photos from google search...
    Roy Ken
  • I would just use an LP generator designed for RVs and hook it to your existing propane supply. That would eliminate having to buy and install a gasoline tank.
    Pick a storage compartment, partition it off. line it with sheet metal, and install the unit. The Onan unit in my TC has installation instructions with it. It would make a good guide for cutting the hole in the floor.
    On a TT I would mount the gen. forward to be nearer the propane and battery even though this would increase tongue weight. Unless you plan on running it all night for AC while you sleep and your bed is in the front. In that case I would think long and hard about putting it at the opposite end of the trailer.
