GVWR 6995# will have a WET tongue weight closer to 840# when trailer is loaded up 'camp ready' (12% of trailer weight)
A Suburban, Excursion (3/4 ton variety) would be a candidate.
Just check door jamb for 'cargo carrying capacity'......that is the amount of weight you can add to vehicle......passengers, stuff, hitch, tongue weight.
Nothing wrong with a 2 wheel drive SRW (single rear wheel) pickup truck in the 3/4 ton variety either.
Either case.....you will need to 'step up' to get in them
(Our 1 ton 2WD SRW truck sits lower then all other models....even 1/2 tons)
