maxum1989's avatar
maxum1989
Explorer II
Jun 17, 2014
picking a truck camper
I am doing my research and need the assistance of the truck camper forum specialists. I have been an RVer for quite sometime but truck campers are a new animal for me. This camper would be in addition to the fifth wheel I currently own and would be used for trips where just my son (12) and I would be going. I am looking for any suggestions I could add to my list of possible truck campers.
Current list of possible campers (all short box models)
Lance 825, 830, 865
Bigfoot 15c8.2, 15c9.5, 15c9.3
And maybe Adventurer 86fb, 89rb-both these getting a little heavy.
My truck is a 2008 2500hd Silverado crew cab 4x4 short box duramax.
Some concerns I have all relate to weight (which I assume is common). I would be pushing the numbers on any of these campers but I am willing to take the shot and give it a try. I know at least one on the list isn't made any more but used is fine so discontinued models are fine to suggest.
So, any models that anyone can suggest that are similar in size and weight to the above list would be greatly appreciated.
Thanks
One thing I should add. I already have Nitto terra grappler tires with a 3750 weight rating already. Lucky break. I put those on last year just because I liked the look. Seems they are a popular tire for the truck camper crowd.
  • maxum1989 wrote:
    ... This camper would be in addition to the fifth wheel I currently own and would be used for trips where just my son (12) and I would be going. I am looking for any suggestions I could add to my list of possible truck campers.
    Lance 825, 830, 865
    Just went through the exact same drill you are now doing except I am running a 2013 F250 SRW. We wanted something else to move more easily than the slow plodding pace of the fiver. After tons of research we opted for the 865 from Lance . Weighs out at about 2080 fully tricked out (no water). We've been running the wheel off it since we picked it up about 3 months ago all over the eastern US mountains and Florida. En-route to Central FL (about 500 miles one way) Thursday for a few days. We love the 865 and found that dealers were readily willing to negotiate well below sticker. It easily holds Momma, me, Shiloh the Red Bone Coon Hound and Sugar the Yorkie.(Shiloh is a bit of a seat hog but we still love her!) We've fallen in love with it. Had to make the usual 5th wheel hitch modification with a small pad to get the camper sitting smoothly and evenly over the 5th wheel hitch cross frame member in the bed. Works great.
    I did add a set of Stable Loads quick disconnects to the rear leafs to engage the overload, Made a huge difference.
    Ford curve control kicked in 3 times on the climb up and down the road to Clingmans Dome in the Smokey's but it was brief and worked well.
  • Do you have secondary springs on the rear axle?
    Either way, maybe stable loads are in order. But, as always, get the TC on before finding you need any suspension upgrades.
    Since you have a large RV already, it would be good to have a small TC on the other end of the spectrum, especially for just two people. Since you are used to 'semi-luxury' in the big-mo, and if I were going out and buying a truck camper right now, from what I've seen, it would be the Lance 865. Be sure to look that one over to see if you could live with it. Here's our same-size camper on the Mojave Road in March: 86" Wide; 10' 3" High; 8 foot 6 inch floor:
    regards, as always, jefe
  • I would add to your list the Lance 845 and Lance 855 models. Your truck can handle the weight IF you add Supersprings to the rear.
    Check your tires as well as if the stock ones are rated at 3200 lbs. each then the two at the rear drive can handle a maximum of 6400 lbs. less the 3,000 lb. weight of the truck leaving 3400 lbs. for the fully loaded camper - which is cutting it close. I switched out the stock tires for Nitto 285's rated at 3750 each. Toyo and BFG also make 17" tires with the higher load rating.
    You may or may not need an anti-sway bar. Get the camper and verify before doing anything other than the Supersprings addition to the truck.
    I spend $445 for the Supersprings and $500 for the new tires (sold the stock tires on my new truck on craigslist) to get the added load capacity for a Lance 845 camper on my 2500HD. I went with the 2500 as the 3500 is not available with an extended cab (now the double cab) and short bed configuration.
    Don't go with air bags. They can break. They need adjustment and can have a negative effect on the truck's handling. Cost is the same as the Supersprings that need no adjustment and will never fail and do not wear out and cost far less to install (my set took less than an hour to install).
    Lance is made in southern California. A good lightweight camper is the Wolf Creek which is manufactured in eastern Oregon and closer to your location so less shipping expense. They have a western Canada rep, Brad Clark (cell 250.549.8818).
  • The Adventurer 80W (2013 was the last model year) fits our shortbox 3/4 ton well.
    For a small camper, it has some good features: 5 cu ft fridge, toilet, north-south queen bed, good floor space (we have two dogs), good counter space, decent storage inside.
  • My son carries a Lance 820 on a truck like yours. He did add air bags to level the truck.
  • They are pricey, but look up Livin Lite truck campers. All aluminum, lightweight. I'd love to have one.
