handye9
Mar 20, 2014Explorer II
stahrmcgee wrote:
Fingers crossed that the TV will be good with it (Max tow package >11,000 lbs capacity), but if a new TV is necessary, that will be the next adventure.
Your weakest point, most likely will be your payload (cargo capacity) of the truck.
Check the sticker on your driver side door post. Some models have as little as 1400 lbs payload.
Whatever it says for cargo capacity or payload, is the weight room you have for everything / everybody you have in or on the truck, plus the weight distributing hitch, and trailer tongue weight.
Your new trailer is over 7000 lbs empty. Loaded for camping, it could weight over 8000, with 950 - 1000 lbs of tongue weight. Then you have to add 100 lbs for the hitch.
44,029 PostsLatest Activity: Jan 28, 2025
