transamz9
Oct 28, 2016Explorer
rickeoni wrote:Perrysburg Dodgeboy wrote:
I wish the LEO's would start ticketing those drivers with the colored headlamps! Seems to me that would be a better money maker then a 7 MPH speeding ticket! The law does not allow high powered or colored headlamps and those bulbs are sold with the disclaimer "FOR OFF ROAD USE ONLY"!
Don
Earlier in this thread you wrote
"All I did was re-adjusted the headlights on my Ram. Parked in front of the garage door at night moved the right headlamp up one inch and the left headlamp half of an inch up. Truck was sitting about 20' from the door.
Now I can see just fine. The other drivers (mostly small cars) are not very happy but that's life. I try and make sure I'm over to the right a little at stop lights, otherwise the poor person in front of me get blinded (again small cars). "
Why are you against others blinding you, but have no problem blinding others?
Personally there's a difference between having your headlights aimed a little high ( a loaded trucks head lights will be high) than having high watt bulbs installed. That's why high beams are so bright, because they are a higher wattage than the low beams.
44,071 PostsLatest Activity: Aug 16, 2026
