troubledwaters wrote:
wildtoad wrote:
Your pipes should be fine. It takes continued cold temp below freezing to freeze the water solid, and even more time for it to freeze to the point where the ice will cause damage.
wildtoad will take care of any fixes needed - just send him the bill.
It takes two things for water to freeze to cause burst pipes: 1. temperature below 32 degrees and 2. time.
The closer the temperature is to 32 degrees, the longer the pipes have to be subjected to below freezing.
1 hour at - 10 degrees is significantly more damaging than 1 hour at 31 degrees.
4 to 5 hours in the mid to high 20's is enough to cause concern. Do the best you can to mitigate any issues by draining the lines as previously posted.
