Bedlam
Nov 14, 2016Moderator
I run a 300w inverter for my TV/DVD without low voltage issues using the 12VDC outlet next to the TV, so it really depends on the manufacturer's original wiring.
If you tie in a larger inverter into the AC electrical feed, add a light switch with indicator light to the AC input feed of your DC charger/converter.
