SLSAntigua
Oct 29, 2013Explorer
One, there does not appear to be a problem with the brake actuator. The break controller still shows that the brakes are on on occaision. Weird sometimes on and sometimes off. Can't tell since if you increase the how much brake to be applied sometimes it will slow the vehicle down and others it is like they are not being applied. both times I am not pressing the brake.
I am not sure of the voltage on the Battery since I haven't tested it. Thinking the battery was completely dead, I connected it to a Diehard trickle charger and it is showing fully charged. I checked fuses but I had no idea there was a box in the front compartment. I think I know what you are referring to. Getting to it is going to be fun. Is there an access to it from inside rv? I guess if that is tripped then putting a new battery in isn't really going to change anything?
