bobndot
Sep 20, 2015Explorer III
After you clean and flush the entire system (more take a few times) using bleach , then baking soda to remove the chlorine taste. Allow each solution to sit and soak the water system, give it time to work.
After you re-winterize with the pink stuff , blow it back out after you put it thru and "winterized everything". There is no reason to leave it in the system at that point. You avoid bad taste that way.
44,068 PostsLatest Activity: Jun 09, 2026
