ShinerBock wrote:
LIKE2BUILD wrote:
The specs on the engine show that peak torque(800 lb-ft) is made at 1700 RPM. See specs at Cumminshub.com. So, what I might guess is at that point of peak torque the engine is getting the most bang per quantity of fuel and running at a fairly high efficiency. I could be completely way off base here, but at least it's a rambling thought.
KJ
Per Cummins Quickserve, peak torque is at 1,600 rpm with the 370hp/800lb-ft 6.7L.
Remember that peak torque is measured at wide open throttle and full boost. So going down the highway at 1,600 rpm sipping fuel with very little boost that engine doesn't make close to that torque value.
