Thanks for replying. I wish I could explain it better... Ill start from the back of the panel.. I have a city connection and the Fresh water connection, vent. That Panel was removed and blocked, I ran water from underneath the TT. On the fresh water tank I have 3 tubes. I am pretty positive 1 is the fill tube, one goes to the pump (bottom one) and top one, i think is the vent tube...? The outlet that feeds the rest of the TT is a harder line. That main line is disconnected as well as all other lines on the pump outlet side. I know it is simple.. but Im missing something. Does the City Water, when connected properly go through the water pump? Or should it have a T to bypass the pump?
