BurbMan
Apr 17, 2015Explorer III
On mine the slideout floor was OSB with some kind of smooth coating on the bottom side, almost looked like Masonite. The edges were treated with some kind of sealant that looked just like Flex Seal. Once a little water got in the side the OSB swelled up like a sponge, causing the edge sealant to open up wide cracks and that was the beginning of the end.
Gorilla tape is good for patching the Darco, I have used it. Sounds the dealer will do a good job for you, post a pic back after you have the work done.
44,066 PostsLatest Activity: May 12, 2026
