Gdetrailer
Feb 19, 2020Explorer III
Mike134 wrote:librty02 wrote:Lwiddis wrote:
And 760 pounds ISN’T enough.
If he does have 760lbs left over why would that not be enough? How do you come to that conclusion without know his situation? :h
I thought the same thing. Forums can be very helpful but need to filter out helpful from just the noise.
Plus the OP already has used a CAT scale so he's well aware of his cargo numbers
REREAD "handye9's" post.
That IS the REAL answer.
For some reason everyone is attached to and obsessed with the "dry weights".
Brochure Dry weights are bogus to start with.
Brochure Dry weights often do not include silly things like a battery and propane.
Brochure dry weights do not include any options from factory or add on options at dealer.
Only the actual weight sticker the manufacturer must place on the trailer will list the real dry weight.
Yes, not "everyone" will use the full GVWR of the trailer, BUT, MANY DO.
And by they way, 13% is the MIDDLE of the recommended range of tongue weight, the HIGHER tongue weight you have the MUCH better the towing experience will be.. Reality is you really want to be 15% not 13%, the trailer gets much more stable at 15% than 13%..
And with borderline or subpar tow vehicles combinations you REALLY want the max tongue weight you can get without going over your TVs axle ratings.
Can the OP tow it, yeah, perhaps, but I myself would not do it..
ASSUME AND PLAN FOR THE WORST CASE SITUATION, the result will be a much, much better towing experience..
44,071 PostsLatest Activity: Sep 17, 2026
